strongest servo
what is the strongest servo on the market?
what is the strongest servo on the market that a basic stamp can run?
thesupermarket.us
fourteensquarefeet.com
thesupermarket.us
You need to be much more specific as far as what specific requirements you need
or are looking for in order to get an answer that makes sense.
Beau Schwabe
IC Layout Engineer
here is a place to start: www.servocity.com
In particular, look at: http://www.servocity.com/html/hsr-5995tg_ultra_torque.html rated at 417 in/oz
coupled with an add-on gearbox, you can get over 2000 in/oz of torque from a standard size servo.
If it is for position and power, a stepper motor may give you more with a direct link rather than leverage.
If it is for rotational power, there are a lot of brushed and brushless motors with gearboxes that can be taylored to your needs.
These servos are not really true 'industrial servos' and are generally considered 'hobby servos'. They make building quickly within a limited size range considered to be mostly for hobby use.
These other units not only offer more direct power, they offer the appropriate sized output shaft and bearings to make them last under greater loads.
