Usb2ser
Hello,
What is the scope of the RES pin on the USB2SER device ?
How to use it ?
Thank you for helping me.
Luca.
How to use it ?
Luca.
·· You can see how the operation is affected by looking at the schematic.· When the DTR line on the serial port (VCP) is brought HIGH that turns on a transistor which brings this line low.· It is similar in operation to the BASIC Stamp ATN line.· In the Projects Forum is a BASIC Stamp 2 OEM thread which shows how to program the BS2 OEM using the USB2SER.· In this case the RES pin resets the BASIC Stamp as required during programming.
csavage@parallax.com
