Does anyone know of a cheap, non-programmable, and simple motherboard that support the BS2? Also, can you use it in your robots if you plan to sell them?
$20 pre-built. Add a BS2 and you're good to go. You can do slightly better if you build your own, but most custom board shops are going to charge you $10 to $20 for a bare board. Add a few sockets and parts, and you can top $20 per board pretty quickly. Now, if you're building thousands, then buying parts in bulk makes more sense. Even then, give parallax a call, they might be able to cut you a deal.
There's a few robot vendors who sell the BOE board along with their robots, so I don't think redistribution is a problem.
The super carrier board is nice, but I don't see where the servers plug in, and i would perfer a board that already has a soderless circuit board attached and is a bit simpler. Would the BS2p24/40 Demo Board support the regular BS2 and would i be able to use it for my robots? I would realy just like somthing with a place for a BS2, a soderless circuit board, and a place for some servers.
Hmm. "Motherboard", "servers", it's beginning to sound like either I'm not understanding you, or you're not understanding me.
What are you calling a "server"? In my work, that's usually an IBM-PC of some description (486, Pentium 1,2,3,4,5, etc) or a Sun workstation, or something like that. Are you looking for a Web Server portal, perhaps?
I'm guessing you're referring to servo's when you mention server. The Board of Education is a popular board that has multiple servo connections www.parallax.com/detail.asp?product_id=28150 and costs $65.
I have a few generic 3 1/8" by 1 7/8" boards that I merely soldered a 24 DIP socket and two 12pin headers along side. That pretty much omits the programing. There is space to a a five volt regulator and a reset button. One could easily put in plugs for 4 servos too. Then you could wire with jumpers.
If I want to program, I have built a DB-9 with the capacitors on the Atn Line that directly connects to the 4 pins of one of the 12 pin headers. But you could just as easily not provide access to those 4 pins [noparse][[/noparse]Tx, Rx, Atn, and Grn] and use an 8 pin header on that side.
A power on Led is also helpful.
I like the Super Carrier board: http://www.parallax.com/detail.asp?product_id=27130
Also, note that the OEM board version of the BS2 is available : http://www.parallax.com/detail.asp?product_id=27291
And it's on special. For $30 you get a BS2 AND the board -- just add wires.
If costs is more important, then the Super Carrier board is a good alternative at $20 and you can add servo connections on the solderless breadboard. You can get a small solderless breadboard here www.parallax.com/detail.asp?product_id=700-00012 for $4.95. and get one of these cables/headers for each servo you want to add for $1.29 each www.parallax.com/detail.asp?product_id=805-00001,451-00303
Who says you have to have knowledge to use it?
I've killed a fly with my bare mind.
