Quick BS2 Timing question — Parallax Forums
SouLJahSouLJah Posts: 35
edited 2006-02-18 18:25 in BASIC Stamp
I am using a ADC to read the values of 2 analog waves, I want to measure the time difference between each wave reaching its peaks, and the time difference is miliseconds apart, what device could I SUCCESSFULLY use to achieve this.· If you have an answer help me out, thanks.
    edited 2006-02-17 20:34
    The problem is that you probably need to sample the waveform several times between the peaks, to accurately determine where the peaks are.
    Also, most A to D converters do take SOME time to sample the signal.
    Also, the BS2 runs at about 300 uSec per instruction -- so you may only be able to take two or three samples between the 'peaks'.
    Short answer -- this could be asking too much of the BS2.
  • SouLJahSouLJah Posts: 35
    edited 2006-02-17 22:22
    Ok, but let me ask if you were measuring short times, what would you use to do it.
    This would probably require some external analog hardware. Two analog peak detectors, one to set a flip flop and the other to reset it. Then you have a pulse duration, and the BASIC Stamp can easily measure that with the PULSIN command.
    The external circuitry required would depend on the shape and cleaness of the signals. A peak detector often consists of a differentiator, followed by a zero crossing detector.
    Tracy Allen
    www.emesystems.com
