RS 485 addressing
My company recently disposed of a few old data collection and control modules that communicate through RS-485.· The address of each seems to be set using dip switches.· Could someone explain to me how rs-485 addressing works esp. the hardware side?
GlennT
GlennT
Jon Williams
If you have 'dip' switches, then it's likely each 'node' (or board) had its switches set to give it a unique address. Then, in the firmware on the board, the processor 'listened' to the RS485 line. When it saw its address, it knew it was its turn to speak.
This also implies a 'master' RS485 device on the bus, to tell each 'slave' address when to talk.
But as Jon says, all of this is in firmware, it's not mandated by the standard.
