Data logging chips: EEPROM and RTC recommendations?
Putting together a data logger: need a fair about of memory (probably 32-64 kbytes). I think I might actually know what I doing (ha!), but want to see if anyone's experience can keep me out of trouble.
I see lots of articles and recommendations for 24LC32 or 24LC65. Will using a 24LC256 be as straightforward?
My preferred vendor (Jameco) does not show the LC parts in the catalog. Near as I can tell from the datasheet, the differences between the 24C and 24LC parts is tolerence to power supply and temperature diffs (LC seems more robust). I'm in a room temp environment with a good regulated 5V supply. I should be able to use the 24C* parts, yes?
For the RTC, I've seen postings extolling the DS1302 and the PWB. Since I'm already using an I2C EEPROM, using the DS1302 makes sense. Can I bus the chips together and save IO pins?
RTC: what have people's experiences been with backup? Supercap? Lithium? I've seen conflicting information on the trickle charge feature of the DS1302; one app note said only use it for supercaps, a quick glance at the dallas data sheet seems to indicate it's usable for Lithium also.
tia...
tia...
I thought I saw an article on using the DS1302 alongside I2C, so I misinterpreted the datasheet. So if I use the DS1307 along side the 24LCxxx, I can do the interfaces to both with just 2 i/o?
