3 Digit High Numbers
Hi gents ive got the seetroon BPP-420 LCD Display, its the one which can display characters 4 lines high.
I was just wondering how difficult it would be to write a program that displays the·text 3 characters high, that way I can fit more information on my screen.
I realise im probanly going to have to write lots of subroutines etc that gets the value and then draws it on the LCD.
Is this practical? and if so can anyone point me in the right direction to do this!
kind regards Lee S
kind regards Lee S
The effect would be a 7-segment look.
LCD Custom Character Creator
http://www.parallax.com/html_pages/products/audiovisual/lcd.asp
Post Edited (PJ Allen) : 2/18/2006 4:22:35 PM GMT
Block them all out on some graph paper.
the bpp-420 has only 8 custum-character slots. these are also the slots that the bpp-420 uses to generate the large font (check out the ascii map in this pdf http://seetron.com/pdf/bpp423.pdf) . you can edit those to resemble a 7-segment map (draw a 7-segment 8 ontop of a 3x3 set of squares for a reference). but if you do you'll have to reset them if you use the large font for text.
drawing the characters will be tricky. you'll want to write a subroutine that takes 2 inputs, the digit and the value it holds. the position command (16) will be your best friend.
try to write a script of your own and post it here if you have any trouble.
good little question you have there,
roxon
nickb
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
