Wiring LCD Parallel in-bit mode
··· Always double checking myself and apologize to all those of you that get stuck reading my dumb questions. OK from the schematic I have PINS 4,5,6, and 7 provide the 4-bits of data. Then the other 4-bits on the LCD are connected straight to ground. Can someone tell me if that is correct? I saw one schematic that did not connect those 4-bits pinouts to anything that would be easier but does not make much sense to me. As you can tell I am far from a electronic wiz.
This leaves you with just 6 pins required for control, the 4 data pins, the enable pin and the register select pin. Don't forget ground and Vdd.
csavage@parallax.com
