increase servo's torque
exskool
my robotic arm seems has problem to lift·an object..how i can increase the torque without modifying the structure?
A smaller drive gear and a bigger secondary.
But I think we know it is not really possible to change the gears in a servos case.
You might be able to counter balance what you are doing with a properly placed spring or a pulley and weight system.
If you wanted to go to an electronic solution, you would have to apply more power to the motor [noparse][[/noparse]that means more volts or more amps]. More volts might burn up the motor and you certainly would have to modify the control circuit. More amps would require that you rewind the armiture coils inside the motor.
Easiest thing to do is just buy a better servo motor that can push harder.
