Pink Flash Fields using HTML
I am trying to setup a HTML page where the following PINK fields are to be updated – INTO FLASH:
Nb_varET – email TO: register
Nb_varEF – email FROM: register
Nb_varEC – email CONTENT: register
Nb_varEV – email SMTP server register
Setting the values through HTML into RAM is not the problem – I am trying to set the FLASH values from a HTML page that does not have links to all the other variables and values.
Any assistance or guidance will be greatly appreciated.
regards peter
As clearly displayed on the html page supplied with the PINK module, there is a Update Flash column which has the option to Set Default Value for the following variables or Special Purpose Registers:
Nb_varES – email SUBJECT: register
The actual use of the Set Default Value does indeed set the values to Flash.
Every problem has a solution. Some don't even create more problems.
