XS 48/52 Proto Board How To
The DIP8 and Servo areas of the Proto Board are like this
········· 0-0
Where one pad is for the IC/servo pin and the other pad can be used for a wire to connect to a SX pin.· How do people connect other pads to a SX pin?· Do you try to get a socket pin and a wire in the same pad hole?· Or solder a wire on the part of the pin sticking out the back of the board?· I want to interface a DIP28.
A second question.· I assume that solid wire is prefered for board to board connections and stranded for off board.
········· 0-0
·· You could use solid 22 or 24 gauge wire to connect the pads together.· I will often use the clipped leads of components I solder into boards for jumpered connections if they don't need to be insulated.· As for off-board stuff stranded wire is usually a better choice, but you may noticed the larger holes around the bottom and right side of the board.· These are to route your wires and act as kind of a wire-guide/strain-relief to keep your connections secure.
csavage@parallax.com
