was wondering
eeh, this is probably a lame question , im no whiz when it comes to programming or electronics, but i do enjoy playing around with my basic stamp microcontroller.
i have the lowest difficultie lvl starter kit and im far from understanding everything that goes on in there.
My question is basically this, my starter kit came with a piezoelectric speaker, but im pretty much a nightperson and my housemate is not, so i was wondering if there is anyway that i could replace the piezoelectric speaker with a set of headphones, and if so, how would i go about doing that?
anyways thats all i wanted to know.
so ... thanks
mattias
so ... thanks
mattias
The piezoelectric speaker [noparse][[/noparse]rather than a simple 4ohm or 8ohm speaker] was provided because it is a safe 'no brainer' audio output.
At 4ohms or 8ohms, you really risk damaging the Basic Stamp without using a transitor circuit to drive them.
It is simply Ohm's Law E=IXR;
5volts = Amps x 8 ohms comes out to 5/8ths amps [noparse][[/noparse]that is about 625millamps].
The BasicStamp can only saftely drive less than 30millamps. 20millamps is safer.
4 ohms is worse as the amps doubles to 1.250 Amps.
Of course, you could just add a length of wire to the piezoelectric and make you own headphone with a coat hanger. You could possilbly add a volume control too.
but i think i get the idea, so i wont attempt to hook up my stamp module to my high voltage amp just yet :P
i just wrote my first program today, by that i mean a program that didnt come out of the book, and i was just hoping to have someone look at it and make sure im not frying my processor.
its basically two buttons, a potentiometer and the lil speaker.
the potentiometer scans its position between 3 ranges like 1 to 100 and 100 to 200 and 200 to 300
depending on its position the frequency duration or pause between the sounds can be modified by pressing the button that adds and pressing the button that substracts values. those creating a sort of machine that will let you tune a beat etc, anyways here is my code.
·' {$STAMP BS2}
·' {$PBASIC 2.5}
·dur VAR Word
·freq VAR Word
·paus VAR Word
·optionnr VAR Word
· freq = 500
· paus = 50
· dur = 50
· DO
· HIGH 7
· RCTIME 7, 1, optionnr
· IF (optionnr < 100) THEN
· IF (IN11 = 1) THEN
· freq = freq + 100
· ENDIF
· IF (IN10 = 1) THEN
· freq = freq - 10
· ENDIF
· FREQOUT 15, dur, freq
· PAUSE paus
· DEBUG CLS, "Frequency = ", DEC5 freq
· ENDIF
· IF (optionnr > 100) THEN
· IF (optionnr < 200) THEN
· dur = dur + 10
· ENDIF
· dur = dur - 10
· ENDIF
··· FREQOUT 15, dur, freq
· PAUSE paus
· DEBUG CLS, "Duration = ", DEC5 dur
· ENDIF
· ENDIF
· IF (optionnr > 200) THEN
· IF (optionnr < 300) THEN
· paus = paus + 10
· ENDIF
· paus = paus - 10
· ENDIF
· PAUSE paus
· DEBUG CLS, "Pause = ", DEC5 paus
· ENDIF
· ENDIF
· LOOP
· END
so ya, pls lemme know if this is the propper way to be doing things, or any suggestions would also be nice [noparse]:)[/noparse]
anyways thanks [noparse]:)[/noparse]
·1+1=10
