Measuring oven temperatures with a basic stamp homework board
I need to measure the temperature changes inside an oven over an extended period of time.
So instead of sitting there watching an oven thermometer for 2 hours, I thought it would be rather nifty to get my Basic Stamp homework board to do the job for me.
On the parallax website they have a thermocouple kit, but it says that it will only work with the BASIC Stamp 2p modules.
Can I use this kit with a Basic Stamp homework board, as the picture claims it has a Basic Stamp 2 built in?
Daniel
Daniel
·· As you pointed out, the H/W Board has a BS2 on-board, not a BS2p, so that still won't allow you to use the Thermocouple device.· A BS2p is still needed for direct interface or you need a serial to 1-wire converter.
csavage@parallax.com
Where can I get this serial to 1-wire converter?
Maxim/Dallas offers the serial to 1-wire interface chips here:
http://para.maxim-ic.com/Default_1WireInterfaceProducts.htm
The DS-2480B is the chip most often used with the PBASIC Stamp.
Bruce Bates
<!--StartFragment -->
Is there a guide to making this serial to 1-wire device?
If not, I'll just have to do as PJ Allen suggested.
Besides, there are plenty of other projects I can use it for.
