Difference between the operation of SX on programmer board or bread board
I got the SX to do a voltage comparison on the programmer board, but when I put it on the bread board it doesn't make the decision
about the voltage levels are the pins. I know the SX is functioning properly because it is sending out serial data that matches up for one measurement being higher, but never the other. I guess what I'm wondering is there something else that needs to be grounded that wouldn't on the programmer or something of that nature?
-John Whitfield
-John Whitfield
Without the project sitting if front of me, it is impossible to check your work.
If you draw and post a schematic of your 'AS BUILT' device, someone can constructively comment.
And possibly, you might identify your problem while creating the drawing.
At times, electronics is a lot of tedious details with wonderous results.
Or a (good) photo of what you built might give us a clue, too.
Steve
- Do you use the SX-internal comparatoer for voltage comparison?
- If so - how did you configure port B?
- What are you using as "programmer board", and what is your breadboard?
Greetings from Germany,
G
