Pressure Sensor? — Parallax Forums
Pressure Sensor?
redmansaredmansa Posts: 1
edited 2013-03-31 11:06 in BASIC Stamp
It seems that parallax no longer carries a barometric style pressure sensor.· Does anyone know of an alternative, something that will read from a low of 25 in mercury to a high of 33 in mercury.· Any help or suggestions on manufacturers would be greatly appreaciated.· I am trying to use this sensor in conjunction with the BS2PE stamp module for a E.E lab project.·
Shane
  • stamptrolstamptrol Posts: 1,731
    edited 2006-02-14 01:17
    Shane,
    See the Digi-Key catalog, pages 1692 - 1693. Or goto digikey.com and search for "pressure sensor".
    Tom
  • Robert KubichekRobert Kubichek Posts: 343
    edited 2006-02-14 01:34
    redmansa said...
    It seems that parallax no longer carries a barometric style pressure sensor. Does anyone know of an alternative, something that will read from a low of 25 in mercury to a high of 33 in mercury. Any help or suggestions on manufacturers would be greatly appreaciated. I am trying to use this sensor in conjunction with the BS2PE stamp module for a E.E lab project.
    Shane
    Here is one site;
    www.atmos.com/products.htm
    Arrow, and Digikey electronics both have sensors, but you would have to interface them yourself.
  • knikulaknikula Posts: 26
    edited 2013-03-30 18:24
    The map sensors used on Fords from 1985 and up ( not sure how far up) put out a variable frequency square wave from about 90 to 160 Hz, which would make them nice for interfacing. The turbo 2.3 Ford and the Super Coupe T-birds would likely have a 2 bar sensor. Might be pretty easy to grab one out of a salvage yard or ebay.
  • garyggaryg Posts: 420
    edited 2013-03-30 18:35
    Just a quick question?
    If perfect vacuum is approx. 28 inches mercury, How do you get to
    33 inches mercury.
    The perfect vacuum thing is something that I thought I understood.
    Thanks for any response to this trivial question.
    edited 2013-03-30 21:15
    Well of course this thread is from 2006... :)
    In those 7 years, I don't recall seeing anyone post about using EG's mysterious but affordable pressure sensor, a bargain at just $1.49...
    http://www.goldmine-elec-products.com/prodinfo.asp?number=G15473
    Who will man up and answer the call? :)
  • doggiedocdoggiedoc Posts: 2,252
    edited 2013-03-31 06:08
    @erco - I might just have to order a few of those to play with.
    See, resurrected threads can be useful. :D
    Paul
    edited 2013-03-31 10:54
    doggiedoc wrote: »
    How appropriate on Easter Sunday! :)
    I wasn't sure if anyone would catch that. :D
