pc serial port connection
I·am working on a project that requires my stamp to be mounted about 20 feet high. However,·I want to be able to program the stamp from the ground. Is there limitations on the length of wire that can be used to connect to my serial port? Also, is there a certain kind of wire i should be using?
thanks for your help...
I'm sure there is a practical limitation on the length, but I wouldn't think that 20 feet would be a problem. I'd use random lay, twisted pair cable, like telephone station cable.
Will this be an indoor or outdoor application? If it's indoors, will there be any fluorescent fixtures nearby?
Bruce Bates
<!--StartFragment -->
Wiring length
The length of the cable also plays a part in maximum speed. The longer the cable, the greater the cable's capacitance and the slower the speed at which you can obtain accurate results. A large capacitance means voltage changes on one signal wire may be transmitted to an adjacent signal wire. Fifty feet is commonly quoted as the maximum distance, but this is not specified in the standard. It is generally recommend a maximum distance of 50 meters, but this depends on the type of hardware you are connecting and characteristics of the cable.
Maximum length of cables
Baud rate [noparse][[/noparse]Bd] Max length [noparse][[/noparse]ft] Max length [noparse][[/noparse]m]
19200 50 15
9600 500 150
4800 1000 300
2400 3000 900
500 feet sounds like a really long cable for 9600 baud -- but probably 100 to 150 feet would work fine, so your 20' rise would not be a problem at all.
How much electrical noise from other equipment is in the area? This may or may not be a concern. Tying a 1K resistor between ATN (pin 3) and VSS (pin 4 or pin 23)
can sometimes help noisy environments where the programming cable remains connected to the BS2.
I have used about 75ft of standard "flat-grey" telephone cable without much problem with the configuration mentioned above.
Beau Schwabe
IC Layout Engineer
Definitely use shielded cable!
Bruce Bates
