modify a servo
nelson1000
I was wondering if someone could take a look at this web page and tell me which servo would be the easiest to modify for continuous rotation. The price range that I am willing to spend is approx 25 CAD max as I have to purchase ~6 motors.
I would like to order from parallax but since I live in Ontario the shipping is expensive.
thanks for any help.
Although they appear to be out of stock at the moment, you can purchase Parallax continuous rotation servos right from the Canadian Parallax Distributor here:
http://www.hvwtech.com/products_view.asp?ProductID=114
Bruce Bates
<!--StartFragment -->
What is an easy servo to modify with "non-metal" gears and ball bearings?
What is an easy servo to modify with metal gears and ball bearings?
I was looking for recommended servo models that others have good luck modifying. Most of my servos have been Futaba S148 and I wanted to move to better units. Some units employ ball bearings and high stress special composite gears. Other ball bearing units use metal gears.
Because these are higher quality, expensive servos, I didn't want buy without knowing they can be eaily modified.
