Solderless breadboard with 2mm grid spacing...
Hi all...
Does anyone know a source for solderless breadboards with a 2mm grid spacing? Does such an animal even exist? I just picked up a bunch of components with mounts that require that spacing, and I really don't want to solder them to anything just yet. I know that the 2mm grid is primarily for production, but I'm wondering if I can prototype with it as well. If there are no 2mm grid solderless breadboards, does anyone know of adapters that can convert 2mm pins to a regular .1 grid solderless breadboard?
Thanks...
Jamie
Jamie C. Pole
Principal Consultant
J.C. Pole & Associates, Inc.
http://www.jcpa.com/
Thanks...
Jamie
Jamie C. Pole
I asked a similar question a while back, not about a breadboard, but an adapter. See the discussion here:
http://forums.parallax.com/showthread.php?p=564793
Paul Baker gave help which worked perfectly for a particular adapter for my project. I have found somewhere 2mm breadboards, but I'll have to look again.
Jim
In the end, it seems that it's all about getting the LEDs to blink....
I think our requirements are similar, so any information that you have would be very helpful. The components & modules that I'm trying to work with seem to be very delicate, so I REALLY don't want to solder them without working through a prototype first.
Jamie
Jamie C. Pole
http://adapt-plus.com/products/ic_sockets/accessories/misc/cat_pic_92.jpg
I think they are maybe more common across the pond....
Jim
Thanks for that info - I'm really looking for solderless boards, but if push comes to shove, I might just buy that board and mount one of the sockets with wire leads that I can plug into a standard solderless breadboard.
Thinking about the mechanics involved with creating a solderless board with a grid that small, I'm not even sure that it's possible.
PJ:
Thanks for the response - I'm trying to find an appropriate breakout board now... A 2mm solderless board sounded too good to be true to me as well.
Jamie
Jamie C. Pole
Post Edited (jcpole) : 2/12/2006 1:31:22 AM GMT
· For what it's worth, Sparkfun has (had?) an interesting account of their experiences with "wave soldering" --·where they finally used a wal-mart electric skillet with what they regarded as very-good/excellent results.· Go figure.
·1+1=10
Thanks...
Jamie
Jamie C. Pole
·1+1=10
Thanks.
Jamie
Jamie C. Pole
·1+1=10
Thanks Paul.
Jamie
Jamie C. Pole
BTW, I used the SparkFun service and was quite happy with the product. If you don't need immediate service, they are quite reasonably priced. Took ~3 weeks I think, submitting Paul's drawing package. Recommended.
Again, if you want one Paul, happy to send one along...
Jim
If you want to check the layers yourself, Viewmate is a free program to view gerber data. Let me know if there are any problems.
Jim: While I eventually want to experiment with Zigbee, its not a priority, so the board would just sit around. Besides when I do get to it Ill need two modules to communicate, but thanks for the offer.
·1+1=10
Post Edited (Paul Baker) : 2/14/2006 3:43:03 AM GMT
Jamie
Jamie C. Pole
Thanks...
Jamie
Jamie C. Pole
·1+1=10
Jamie
Jamie C. Pole
Since this is my top search result for 2mm breadboard (which doesn't seem to be a thing yet), I am commenting my solution that is a little janky.
I bought 2mm female to 2.54mm male jumper wires. $8, everything is removable and reusable including the breadboards I already have.
I've attached the Gerber files.
Anyone can submit these zip files to OSH Park and have some made.
The ten position strip has a small protrusion to make it meet OSH Park's 0.25" minimum width requirement.
2mm headers are available from lots of sellers online.
