Video Motion Sensor
This looks interesting, much better than a PIR for motion detection, but of course a camera would be required. Could have some possibilities for EFX and robotics.
kelvin
www.saelig.com/miva/merchant.mvc?Screen=PROD&Product_Code=VI001&Category_Code=VI
kelvin
·Thanks for this post
Sam··········································
The idea would be to " scan " the sensor on the different sense points in a subroutine, and take the output from each sensitivty mode, and use logic to determine at what range the activation was acquired.
For example, 0 = low 1 = med low 2= med high 3= high. A scan of the four may only show an output from 0, that would be the closest distance to the cam , or a scan may show an output from 0,1,2 and 3, the farthest distance. A possible mix of outputs from 2 and 3 would closer than 3, but farther than 1. The whole process should not take a lot of time to function, as it is all just pin switching, and the stamp doing the logic. Being a video feed, i am not sure what type of distance ranges could be acquired, probably depends on the quality of the camera itself ( resolution ). Its just theory, not sure if it could work or not.
kelvin
