Sharp GP2D02 IR Ranger help — Parallax Forums
Special_KSpecial_K Posts: 162
edited 2006-02-13 19:07 in BASIC Stamp
I just got two Sharp GP2D02 IR Rangers. I downloaded the basic stamp app on the site.
http://www.acroname.com/robotics/info/examples/GP2D02-4/GP2D02-4.bs2
However the output from the range finder shows a constant number of 255 during the 100 distance check loop. The interfacing diode is in place. I have tried to hook a 33uF capacitor between the basic stamp II and the red wire leading to the VDD as stated in this document
http://www.acroname.com/robotics/info/examples/GP2D02-4/GP2D02-4.html
Any suggestions?
  • dandreaedandreae Posts: 1,375
    edited 2006-02-11 00:23
    Double check your I/O pins and make sure that they are working properly or change to a different set of I/O pins and then modify the code.· You may have a defective Sharp GP2D02 IR
    sensor?
    Dave
    Dave Andreae
    Tech Support
    dandreae@parallax.com
    Http://www.parallax.com
  • Special_KSpecial_K Posts: 162
    edited 2006-02-12 05:30
    I checked the pins and changed the code. I found that the capacitor I was using was a 10uF capacitor. So I have a question is ther a type of 33uF capacitor I should be using? I found these onlinewebtronics_1883_83824253webtronics_1883_82434946
    is there any special one I should get or does anyone have a link to a site they get this type of item from? Has anyone used the· Sharp GP2D02 in a project, and if soo do you have any pictures of the setup?
    Post Edited (Special_K) : 2/12/2006 5:35:12 AM GMT
  • TiboTibo Posts: 81
    edited 2006-02-12 08:07
    Did you tested without capacitor ? If the 'reset' issue doesnt not rise, then forget the capacitor...
    That's got it.
    Thanks!
