SED1520 lcd how?
Jos
Hello,
I have bought a DIP122-5NLED lcd display with two SED1520 controllers, the company told me it is HD44780 compatible. (specs at: www.lcd.elementy.pl/lcd/pdf/dip122-5.pdf )
But no I have the LCD, i think its not HD44780 compatible. There is nothing in the datasheets about HD44780 compatibility?
My question is, is there someone who has a pinout for a Basic and/or Javelin stamp.
I’m also looking for sample code to get this LCD working.
I prefer Javelin stamp examples, but examples in basic are of course also welcome.
Thanks.
Jos
Thanks.
Jos
Meh. Nothing here, move along.
Half the doc. is in English, most of the German part is a reference to the SD1520 User manual.
The sed User manual: http://www.hantronix.com/downhttp://forums.parallaxinc.com/sed1520.pdf
Post Edited (Jos) : 2/10/2006 12:48:19 PM GMT
I think my code may be adaptable but I don't have it with me right now (it also contains my pinouts). I will look into this more later today (or this weekend) when I get home.
-Jon
BTW Translators don't work.
Rafael
Since the Manual is in English though, I don't see too many Problems...
http://forums.parallax.com/forums/default.aspx?f=21&m=108864
This person made a project that uses a 44870 and they include hookup descriptions, and code. (just use the code you need to get the display to work)
But without success [noparse]:([/noparse]
· I'd U/L the PDF, but this way takes up less room on the Forum.
· I think that it has much in common with the 44780.·Looks like·one difference is that isn't 4-bit/8-bit selectable (only 8-bit.)
Keep in mind that this code was a quick test, I recovered the LCD from an old printer and I just wanted to see if i could interface with it. I may try and work on fixing the code to match the SED1520 but I'm not sure when I will have time...
I found some sed1520 code, I translated it to Java to run on the Javelinstamp.
But without results [noparse]:([/noparse] I just want one pixel to light up! At that point I can handle the rest.
