Just a question of hardware(Flexible Buttons)
I'm thinking about starting a project for my math teacher at school. I need about 100 flexible, flat, large area, bendable buttons(Yep. all those requirments). I'm pretty much trying to make rollable keyboard but i do need the buttons to be rather large(~1-4 inches(4X4)). I was wondering if anybody could point me in the right direction.
Regards
Regards
Check out this post about force sensitive strips from a week or so ago: (from about 15 threads down)
http://forums.parallax.com/forums/default.aspx?f=15&m=108173
Check out the references at the end as a patent for use in a keyboard is listed.
An alternative technology is the the Flexpoint Bend Sensor from www.flexpoint.com They are variable resistors which change resistance as you bend them. Only 5/1000" thick
I found Flexpoint last year at the Sensors Show in Chicago, only a few booths away from Parallax. I believe that they are in the few dollar range at 100 pcs.
I hope this helps.
Rick
