Data storage
Dear friends,
I need to use a data storage device with a RTC.
As I was looking for help on the web I found a product from Rogue Robotics, (http://www.roguerobotics.com/products/electronics/ummc)
- uMMC Serial Data Module .
It seems as a good solution for my needs.
Does·anyone have any example code that could help me?
Thank you friends
Michael
Thank you friends
Michael
Unless you're looking for a large amount of removable memory for storage, most chip manufacturers who make RTC chips realize that there will be some users who need to store a limited amount of information in non-volatile memory. Due to that need, they make RTC chips with memory on board. I suspect the uMMC may a bit of overkill, and costly overkill at that.
Bruce Bates
<!--StartFragment -->
My project is a wind data logger. The amount of data is large·and I intent to replace the memory card
every some time for data processing in the office. That's why I am looking for example code for this product
Regards
Michael
You should contact the folks at Rogue, they're very nice. I worked with the mMP3 player and found that it worked well and when I had questions they were quick to answer them.
Jon Williams
You should be able to adapt the code found here:
http://www.roguerobotics.com/node/71
Any further questions should probably be directed to that Rogue Robotics Forum, since that device is not supported by Parallax.
Bruce Bates
I will start with this example and then contact Rogue Robotics.
Michael
The 12-byte limitation is due to the amount of variable RAM in a Stamp.
Sid Weaver
Do you have a Stamp Tester yet?
Michael·
http://www.ghielectronics.com/index.htm
They have both the Alfat and soon to be uAlfat that may work for you.
Cheers,
- Bob -
