Adding RAM
I'd like to add 128Kb (16kx8) RAM to a microcontroller project but don't know what to use.· Any suggestions?
www.speechchips.com
Speech & Video IC's for BasicStamps
www.speechchips.com
Jon Williams
·1+1=10
Jon Williams
·1+1=10
·1+1=10
It's very simple to address though, just put the address on the ports and read back the data on another port.
Digikey has them. $2.50 - $3.00 for onesies.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Ability may get you to the top, but it takes character to keep you there."
This is what I found.
CY7C1399B-15VC
IC SRAM 32KX8 3.3V ASYNC 28-SOJ
1 - 1.89
25 - 1.51
100 - 1.71
I looked at the ramtron FRAM but it's more expensive.
www.speechchips.com
I wonder what the differences between the 2 chips are?
www.speechchips.com
·1+1=10
CY7C1399B
Products : Memory : Async SRAMs : CY7C1399B
256K (32K x 8) Static RAM
Features
Single 3.3V power supply
Ideal for low-voltage cache memory applications
High speed
10/12/15 ns
Low active power
216 mW (max.)
Low-power alpha immune 6T cell
Plastic SOJ and TSOP packaging
CY62256
Products : Memory : Wafer & Die : CY62256
Features
Temperature Ranges
Commercial: 0°C to 70°C
Industrial: -40°C to 85°C
Automotive: -40°C to 125°C
High speed: 55 ns and 70 ns
Voltage range: 4.5V-5.5V operation
Low active power (70 ns, LL version, Com'l and Ind'l)
275 mW (max.)
Low standby power (70 ns, LL version, Com'l and Ind'l)
28 µW (max.)
Easy memory expansion with /CE and /OE features
TTL-compatible inputs and outputs
Automatic power-down when deselected
CMOS for optimum speed/power
Package available in a standard 450-mil-wide (300-mil body width) 28-lead narrow SOIC, 28-lead TSOP-1, 28-lead reverse TSOP-1, and 600-mil 28-lead PDIP packages
Also available in lead-free packages
The CY7C1399B looks faster, cheaper and 3.3V which is fine by me.
Bean, does that make sense to you? Maybe you should add some RAM to your video device and get hi-res or color.
www.speechchips.com
Yeah I would love to add RAM to the video modules, but too damn busy...
I haven't found an easy way to do color NTSC, I could do VGA, but I don't know if that would fly ?
Bean.
·1+1=10
The CY7C1399B-15ZXC looks acceptable. I don't understand your point about lead free. Excuse my inexperience but is there some additional hassle with lead free parts?
www.speechchips.com
Post Edited (KenLem) : 2/8/2006 9:53:43 PM GMT
