Communication between COM1, 2, etc. and a Boe-Bot
Is there any way currently avaliable to transmit data to a Boe Bot from a COM1, 2, etc.
We are looking for a way to build an alternative editor and tokenizer for the BS2.
(A tokenizer engine/library we still have to find)
-The JKL Tech team
(Edit: Would this be a good tokenizer for a multiple OS? We are currently developing
the software on a Linux and Windows Interface.)
-The JKL Tech team
shlb
89K
See my response in the last thread...
http://forums.parallax.com/showthread.php?p=569707
Post Edited (Tom Walker) : 2/8/2006 2:19:21 PM GMT
2. Parallax HAS written a tokenizer for their PBasic language already. Perhaps you can 'port' that?
3. The BS2 is programmed in PBasic 'tokens', which is read by a PBasic 'engine' programmed into the 16C54 PIC chip on the BS2. It has 2000 bytes of EEPROM 'token' storage, and 26 bytes of RAM.
It is VERY good at 'slow' real-time tasks -- on the order of tens of milliseconds. It is NOT very good at high-speed data throughput, or multi-tasking at a sub-millisecond rate. If you can live with those limitations (and LOTS of people do, all the time) it's a wonderful platform.
4. Re-programming it on-the-fly is quite possible. Parallax has published the specifications on their web-site. Why you would want to, and what you achieve by doing so, and how valuable the result would be, is debateable. But I believe the resources are there.
5. Oh, and you can communicate with the on-board serial port easily. From the BS2 side, it's:
SERIN 16, 16384, [noparse][[/noparse]DEC MyVar]
SEROUT 16, 16384, [noparse][[/noparse]"Hi!", 13]
And I assume you know how to open a serial port from the PC, assign a 9600 baud rate to it, and send and recieve data.
http://www.parallax.com/html_pages/downloads/tokenizer/tokenizer.asp
Jon Williams
We are currently developing it under Windows with Liberty BASIC (http://www.libertybasic.com) and Linux
with C. A *.shlb file is a linux program extention file, just like a DLL for Windows.
