Help - Cant download to BS2
Lee_Speakman
Hi everyone, thanks for taking the time to read this, my names Lee and I study Electronic Engineering at Liverpool University - England.
Im having trouble with my BS2, its been working fine then·for some Reason I cant get the system to find the basic stamp. The COM Port reports LOOPBACK 'YES' and ECHO 'YES', ive checked the continuity of the connections and all seems fine, Its powered by PIN 24, with 9v In, I know its getting sufficent power as the 5v out (Pin 21) Is able to power an LCD screen inc. Backlight, even with this Disconnected Im not getting any recognision,
Any help would be greatly apprechiated!
Lee S
Lee S
If you're using a 9 volt battery, try putting a new one in.
Bruce Bates
<!--StartFragment -->
Try this trouble-shooting list:
1. Is the serial cable a null modem cable? If so, it won't work.
2. Is there a serial port driver problem with your PC? (if using USB-Serial adapter, is it working?)
3. Is the power coming off the mains adaptor 'clean'?
4. Is the power the correct voltage? (check with multimeter)
Even if the mains adaptor is working and the BS2 powers on, try using a 9v battery or 4 AA batteries.
Hope this helps.
Caleb
csavage@parallax.com
