Toddler turning
hexbot project
I'm new to the programming of the Toddler hexbot, but i tried to program the toddler with the turning program that is provided on the Parallax website, but when i run the program the Toddler does not turn at all, he just moves forwards and backwards.
Is there something wrong with the program itself or is the servo backwards?
I would really be thankful if someone could tell me what is wrong with the Toddler
Justin
Justin
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
I don't think that switched servos will cause the Toddler to cease turning. The operation is quite different in sequence.
Centering the servos and getting a good straight walk established before moving on to turning is quite helpful as you begin to wonder if your code is wrong or your mechanical set up is wrong.
If you can be sure the mechanical is right, you have eliminated going back and forths between topics. A lot of confusion may be avoided.
Dave
Dave Andreae
Tech Support
Or is there a Toddler Hexbot with both?
