7 seg display problem PDB
I just got the stampworks kit about a month ago;·and while doing the LED lab, found segments E and F are tied together on all 5 seven segment displays.· When I turn one pin high with just one wire to either pin E or F both segments light.· Has anyone else had the same problem or is this just a isolated problem?
Jon Williams
·I appreciate·your timely response.
I did as you said and both segments still light.
Thank you for the information.· I also found your response to anothers problem with latency very helpful.·
Thanks again·for your help.
Greg Roebke
Give our Tech Support group a call (888-99-STAMP) and they'll assist you in getting your PDB returned so that we can repair it for you. Sorry for any inconvenience the problem has caused you.
Jon Williams
Jon Williams
