PINK question on functionality with a BS2 or SX28
At work we use SIXNET I/O modules and Acromag I/O modules to communicate over MODBUS. We currently have simple 24 vdc switches setup to turn on various input ports on the SIXNET input module and Acromag Input module which then sends a signal over MODBUS letting the system know that those inputs are ON.
What I want to know is if·a PINK can be controlled over a webpage to turn on / off a BS2, BS2px or SX-28 output which can then be used to replace the switches setup into the SIXNET and ACROMAG input modules?
I think the answer is yes but I would rather have confirmation before an order is made.
I'm also thinking that the SIXNET and ACROMAG modules will have to be powered by 5 vdc or go through some solid state relays if we have to use 24 vdc.
Comments?
Thanks.
Comments?
Thanks.
You can even see the LED turn on and off if the nearly real time video is on.
Regards
http://forums.parallax.com/showthread.php?p=568514
regards peter
