Connecting Gears
Logan
The Parallax Stepper motors (http://www.parallax.com/detail.asp?product_id=27964) come with a 17 tooth brass gear already attached. Does anyone know how I can determine what gears will match with the Parallax gears? There is nothing on any product data sheets about the type of gear attached.
# teeth / circumference (in·or mm) = teeth / in or mm
If the gears that you buy have a smaller diameter hole, you can drill them to fit and then glue them to the shaft with Locktite.
It seems that the gears are glued on and you will likely have to destroy the existing gear to remove it. This can be done by cutting nearly all the way through the gear with a small file. Usually gears are made of softer metal than the shaft and often the teeth are only hardened.
In theory you can buy a gear puller, but I haven't located one. Hitting with a hammer may work, but you run considerable risk of a bad hit damaging something.
If you merely want to attach a wheel, you might look at collets designed for model airplane motor shafts.· These offer a nice direct transfer of power and allow you to bolt on and off any wheel or pulley you want.· Collets are needed for small shafts in order to get a good grip.· Set screws will not hold well and often shake loose.
Post Edited (Kramer) : 2/6/2006 4:06:01 AM GMT
Thanks ALOT!· I really thought there was more to it than that....
http://www.wmberg.com/
http://www.sdp-si.com/
Chris I.
If you look around, you might find an AC motor that is geared down and you can cannibalize it for very nice brass gears that are in matched sets.
Typically, there are a variety of these that work off the 60 cycle AC to produce 1 RPM, 60 RPM, etc.
At least that gives the teenagers out there a ready supply.
Cheers.
Just tossing my two bits worth into the bit bucket
KK
