Looking for Force Sensitive resistor strips
I was wondering if anyone knows of a source for FSR strips. I am looking for something like a ribbon controller. About 5-12" long and about 1-2" wide. Variable resistance based on position (not force), something like a voltage divider.
Thanks for any help.
Tony A
Tony A
Thanks. I did come across this company but it turns out the FSR is only responsive to force and not position. I'm looking for something that will work like a linear potentiometer, where you will get different resistance readings based on where you are touching the strip. (Like a slide pot).
Thanks again,
Tony A
www.qprox.com/products/qslide_qt401.php
kelvin
Thanks again. This looks interesting. I appreciate your help.
Tony A
I don't know if they still do this, but at the time I was able to get this sensor through TekScan's "Custom"
FlexiForce Sensor as an overage of stock that they happened to have from another customer.
www.globalspec.com/FeaturedProducts/Detail/Tekscan/Custom_FlexiForce_Sensors/18353/0
Beau Schwabe
IC Layout Engineer
infusionsystems.com/catalog/index.php/cPath/24
Cheers,
Tom
Thanks for the info and references, I appreciate it very much.
Tony A.
