drill size for 4-40 screws
Paul Baker
I was trying to find the diameter of standard 4-40 machine screws to be used in mounting a PCB, from what I can find I think they are 0.093" or 0.095". Would a 0.1" drill be sufficiently large, or do they not account for the threads when giving the diameter?
·1+1=10
·1+1=10
0.100 would work but I usually use 0.125 to allow for some tolerance on the placement of the mating part.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Ability may get you to the top, but it takes character to keep you there."
·1+1=10
Chris I.
Usually a smaller bit [noparse][[/noparse]if it isn't so small as to break] will cut faster for a first-time hole.· And it usually allows you more control for accuracy.
After that, you can go up to an appropriate size.
I learned this when I had to drill 5/8" holes in 1/2" steel plate.· If I started with a 1/16" or 1/8" and then did the 5/8" hole, it took a few minutes with a·3/8" chuck electric·drill.
On the other hand, even with a sharp 5/8" bit it seem to take hours without the pilot hole.· And, the drill bit wanted to skip away from the center.
You can't drill a through-hole with a center bit, but you can start it where you intend it to be.
I've never seen anyone use a centerbit on a drill press, but I expect it would work.
(Personally, I've found that a center punch provides enough of a starting hole to prevent drift.)
·1+1=10
