Person counter loop
I'm still working on that person counter I posted about yesterday. Now I'm trying to figure out how to make the loop detect a person (in9 = 0), record the event (people = people + 1) and wait until the person leaves (in9 = 1). Right now what I have is supposed to do this, but whenever it detects someone in front of the sensor, it starts adding continually to the people varible. I already tried using a time delay, and it works, but I want this to be more advanced than that.
Thanks again.
Caleb
Thanks again.
Caleb
csavage@parallax.com
detect:
if sensor = low then
person = person + 1
go to cont
endif
go to detect
cont:
if sensor low then cont
go to detect········· 'if sensor goes HIGH· this will happen
Sid Weaver
Do you have a Stamp Tester yet?
This is an application where manually debouncing your sensor input will help.· If you think about it, humans don't move particulary fast (relative to micros), so you can use a bit of code to make sure that your person sensor is active or not.· I would do something like this:
Check_Sensor:
· sensor = 1
· FOR idx = 1 TO 10
··· sensor = sensor & ~irInput
··· PAUSE 25
· NEXT
· RETURN
What this routine does is make sure that the person is present for at least 250 ms before·he/she is flagged as being present.· This will prevent sensor bouncing as a person enters/leaves the sensor zone from disturbing your count.· With sensor·and done being·bit variables, you can simplify you count code like this:
· peopleCount = peopleCount + (sensor * done)
With this, the only way peopleCount can be incremented is for both sensor and done to be "1."
Jon Williams
Jon Williams
