BS2 sx and parallel 122 x 32 Graphics LCD
Is there someone who have already tried this or have a little sample code ?
please no serial as my lcd is a parallel HY-12232. Here are the technical specs
www.selectronic.fr/upload/produit/fichetechnique/86901.pdf
I find this thing is confusing and i don't know if i can use it as a 'normal' parallel lcd.
I found there's also mentionned C1 and C2
what are those things ?
in other words how to i make work this stuff with the bs2 sx ?
Thank you for your help
![shocked.gif](http://forums.parallax.com/images/smilies/shocked.gif)
![smile.gif](http://forums.parallax.com/images/smilies/smile.gif)
It appears that the answer is no, I see no means for providing ASCII data display, it appears to only be a graphical display, meaning you would have to update the display pixel by pixel.
I see no C1 and C2, but CS1 and CS2 are chip selects for each of the driver chips.
You could use a BS2sx with the display, but like I mentioned before you would have to update the display in a graphical form meaning storing a font table in memory etc.
If you are looking for a (relatively) inexpensive graphic LCD which supports both graphic and text modes, you may want to consider: http://www.allelectronics.com/cgi-bin/item/LCD-101/365/256_X_128_LCD_PANEL_.html
I haven't used it, but I have looked at the spec sheet several times, and people report its not that difficult to interface with and Duane Becker has a site covering using the dispaly here: http://www.sover.net/~snowleop/gdisp3 and also offers a daughterboard to do more things like line drawing etc.
You may also want to consider Matrix Orbital displays: http://www.matrixorbital.com/index.php?cName=lcd-mop-graphic-lcds·and Crystal Fontz: http://www.crystalfontz.com/products/index-grph.html Though I haven't personally confirmed if any of thier LCDs I pointed to support ASCII mode updating.
·1+1=10
Post Edited (Paul Baker) : 2/3/2006 5:02:03 PM GMT
Next time i won't buy again this horrible LCD thing but for now it's too late.
·1+1=10
I'll rather try to see if i can do something with the shop where i bought as this lcd is still untouched, no soldering on it. With a little luck maybe will they accept to swap this with one serial. However thank you for your kind replies and ideas
