A Job Well Done Parallax!
Eric R
Just got my Professional Development Board yesterday and had a little time to play with it tonight. I must say, you guys did a wonderfull job on this board. The layout is perfect and the LED's are nice and bright. It even has a few things that I have wanted to try but never got around to ordering all the parts to make it happen (like the clock and audio amplifier).
I know everyone has a wish list but here is mine..... All this thing is missing is a nice "mounted" stand alone serial LCD display (possibly #27979) that compliments the Pro Board and could sit on your desktop within easy viewing while developing. We all know how the LCD likes·to flop around on the bench
Thanks Parallax, another job well done.
Side view:
······························ ·· · ·/ / <--- LCD slides in here
===========·· / <---- PCB
Charlie
Post Edited (dy8coke) : 2/2/2006 3:55:28 PM GMT
How about a picture ? I like to see how you did it.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Ability may get you to the top, but it takes character to keep you there."
made of methacrylate
and indeed very well made and effective
regards
Stefano
P.S. I'm still not able to obtain much results with the search tool of the forum.......
it is me not clever enaugh or the search option is not really working?
Post Edited (ellizard) : 2/2/2006 5:51:19 PM GMT
I have not made the holder, it was just a quick idea off the top of my head when I read the original post.
Charlie
John R.
8 + 8 = 10
it is still there, but i recall from a post that it was fixed.
thank you for the clarification
regards
Stefano
Mike S.
- Rick
·· Your case is almost exactly what we used in some POS systems back in 1992.· Smal plastic cases from Radio Shack that held the LCD and we milled out a semicircle in each half on what would be the bottom and mounted a collar designed for conduit.· This allowed the unit to sit on a pole much like commercial POS displays which at the time were VERY expensive.· Nice work though.·
csavage@parallax.com
That was the first thing I made with the micro mill I got for Christmas.
It has a few flaws, like the display being just a bit off center and the hole for the contrast adjust doesn't line up too well. Also, about 2 minutes after I drilled the holes for the mounting screws I realized I could have put them in the back instead and had nothing but the display opening in the front panel.
Since the box only cost about $3 I think I'm going to buy another one the next time I order stuff from Mouser and see how much better I can do.
If anyone else wants to make one like this, the box is a PacTec JM24 type, the Mouser part number is 616-7100-510-000. The plastic is pretty soft and easy to work.
Be advised that as you can see in the first pic below, the box is actually too small to fit the display, I had to mill out a relief area about 1/64" deep to clear the contrast adjust pot. You could probably just as well cut a hole the size of the pot.
If you look close in the second pic, you can see how I taped a thin piece of clear plastic (cut from some blister pack) over the front opening to protect the display from scratches.
- Rick
Ryan
Ryan Clarke
RClarke@Parallax.com
·· Thanks for posting the specifics...That way they can do something similar if they want.· I know I have seen something similar done for some of the WinAMP displays floating around the 'net, but nothing as clean as yours.
It's a Proxxon MF 70. Unlike some of the other so-called micro mills, this one really is. It only weighs about 12 lbs. It does a real good job, very precise and well-made. I'd like something bigger someday, but right now I'm in an apartment and my workbench is literally in a closet.
Believe it or not, I usually use the mill right about where is sitting in the pic, on the kitchen counter. Easier to clean up the mess there.
Parallax screwdriver for size comparison [noparse]:)[/noparse]
- Rick
That looks VERY handy. Great deal at around $300.
Here is a CNC'ed version...
www.timgoldstein.com/cnc/Proxxonconversion.asp
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
