USB to SERIAL
Hi there,
I bought a USB to Serial adapter from engros cause i live in canada and ordering the model from parallax would cost me +90$ so i bought it for 60 locally. And i have a problem with it. It comes with a CD, i install driver it works fine except the BASIC stamp doesnt detect it LOOPBACK and ECHO are YES and version and name are blank. The model is BELKIN USB PDA manufactured by BELKIN. The computer assigned com port 7 and i use it at absic stamp still no detection.
Thanks alot
P.S. when i run identify pn the adaptor i ave 3 lamps (Tx, RX, LINK). Link is always green. After i run identify it blinks along with the other too than it stops and basic stamp doesnt detect anything.
basic stamp 2.2.5
Thanks alot
basic stamp 2.2.5
·· The Belkin models do not fully implement RS-232 standards and support and therefore do not work when programming a BASIC Stamp.· You will need an FTDI, KeySpan or Radio Shack brand unit.· These are the brands we have tested to be compatible.
csavage@parallax.com
Post Edited (Robostooge) : 2/2/2006 2:48:10 AM GMT
Tom Smuts
IOGear, FTDI, and Keyspan are other generally available USB to serial adapters that have worked. Don't buy the PDA versions, though.
http://www.tripplite.com/shared/pdf/manuals/932072.pdf
regards
Chet
Tom
