Ping scanning question.
I have more questions unfortunately. I've installed the Ping))) adapter kit and the Ping))) sensor. I also downloaded the RoamingWithPing.bs2 file. I'm using the ping and the IR detectors to roam like the program says. I'm using the standard Servo from Parallax.
· When the Servo scans the Ping left it doesn't go a full 90 degrees, when it scans right it goes a little over 90 degrees. It appears to go left about 75 degrees, then center, then right about 75 degrees, then right 110 degrees (that's what it appears anyway). It appears there's 1 step to the left and 2 steps when it goes right. This is·the first standard servo I've used, I didn't want to mess with the servo range for fear of damaging the servo. Can someone tell me what to do to correct this.
csavage@parallax.com
