Shortening redundant code
Hey guys.· I am going to be using the I2C command set alot for this project that i am working on.· Here is a snippet of what i wrote
I know that i should be able use one SendIt command that would have all the I2C stuff in it and just send the variables to it.· I can write it like this
i cant understand how to send the data to the variables and to the SendIt subroutine
It's Only A Stupid Question If You Have Not Googled It First!!
' ------------------------------------------------------------------------- ' Subroutine Code ' ------------------------------------------------------------------------- FontSequence0: I2CStart SDA 'Display First set of sequence I2CSend SDA, TopSlaveID I2CSend SDA, $60 I2CSend SDA, $00 I2CSend SDA, $01 I2CSend SDA, $00 I2Csend SDA, $01 I2CStop SDA Pause ScrollSpeed I2CStart SDA 'Display Second set of sequence I2CSend SDA, TopSlaveID I2CSend SDA, $60 I2CSend SDA, $01 I2CSend SDA, $00 I2CSend SDA, $01 I2Csend SDA, $00 I2CStop SDA Pause ScrollSpeed Return FontSequence1: I2CStart SDA I2CSend SDA, TopSlaveID I2CSend SDA, $60 I2CSend SDA, $02 I2CSend SDA, $03 I2CSend SDA, $04 I2Csend SDA, $05 I2CStop SDA Pause ScrollSpeed I2CStart SDA I2CSend SDA, TopSlaveID I2CSend SDA, $60 I2CSend SDA, $03 I2CSend SDA, $04 I2CSend SDA, $05 I2Csend SDA, $02 I2CStop SDA Pause ScrollSpeed I2CStart SDA 'Display Second set of sequence I2CSend SDA, TopSlaveID I2CSend SDA, $60 I2CSend SDA, $04 I2CSend SDA, $05 I2CSend SDA, $02 I2Csend SDA, $03 I2CStop SDA Pause ScrollSpeed I2CStart SDA 'Display Second set of sequence I2CSend SDA, TopSlaveID I2CSend SDA, $60 I2CSend SDA, $05 I2CSend SDA, $02 I2CSend SDA, $03 I2Csend SDA, $04 I2CStop SDA Pause ScrollSpeed Return
FontSequence2: I2CStart SDA I2CSend SDA, TopSlaveID I2CSend SDA, $60 I2CSend SDA, $20 I2CSend SDA, $0A I2CSend SDA, $06 I2Csend SDA, $20 I2CStop SDA
Wing Var Byte M0 Var Byte M1 Var Byte M2 Var Byte M3 Var Byte SendIt: I2Cstart SDA I2CSend SDA, Wing I2CSend SDA, M0 I2CSend SDA, M1 I2CSend SDA, M2 I2CSend SDA, M3 I2CStop SDA
SXB
9K
As you figured out, your code is redundant (always sending four bytes) so you could create a subroutine like this:
Update_Display:
· temp1 = __PARAM1
· temp2 = __PARAM2
· temp3 = __PARAM3
· temp4 = __PARAM4
· I2CSTART SDA
· I2CSEND SDA, TopSlave
· I2CSEND SDA, $60
··I2CSEND SDA,·temp1
··I2CSEND SDA,·temp2
··I2CSEND SDA,·temp3
··I2CSEND SDA,·temp4
· I2CSTOP
· RETURN
Of course, you'd have to define this at the top of the program like this:
Update_Display··· SUB·····4
... and then -- here's the cool part --·you can call it from your program like this:
· Update_Display $00, $01, $00, $01
This will be easier to code, and save a lot of space as you're·expanding·fewer I2CSEND instructions.
Jon Williams
Post Edited (Jon Williams (Parallax)) : 2/1/2006 8:41:41 PM GMT
thanks, Brian
Jon Williams
I2Cstart SDA, TopSlave
Can the address to the i2c chip be on that line? It is not shown that way in the example
Jon Williams
·1+1=10
Jon Williams
Post Edited (Jon Williams (Parallax)) : 2/1/2006 3:42:10 PM GMT
I think what has you confused is that Jon wrote "I2CSTART SDA, TopSlave"
I believe he meant:
"I2CSTART SDA"
"I2CSEND TopSlaveID"
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Ability may get you to the top, but it takes character to keep you there."
Jon Williams
