Is faster really more problematic?
Folks I am writing code to generate on/off signals at 12.5us on/ 12.5us off. Is it more reliable to write and execute such a program at 50MHz rather than 75MHz? Does the SX get really hot at 75MHz and possibly miss critical commands? I would prefer to keep mine at 75MHz, but if that produces too much heat and a zero compare is missed in decsz command then my accuracy goes haywire. Would it be beneficial to check an overflow bit every now and then or run it more slowly? Or are these concerns more theoretical than anything?
Thank you, B.
Thank you, B.
Basically when you set an I/O pin it may not read back that state for a cycle to two at very fast clock rates.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Ability may get you to the top, but it takes character to keep you there."
Nate
Post Edited (Nate) : 2/1/2006 10:00:30 AM GMT
