Excel and the BS2
Trying to figure out this StampDAQ thing and have a few questions.
Looking at the Excel·code:
If chkReset = True Then
··········· stamp.SendData ("22")·· 'Tell Stamp to reset
··········· Exit Sub
······· End If
Can you send a reset command to a BS2? I mean, it works in the StampDaq program but there must be more to it than sending a 22 or is it that simple?
Here is my project:
1 Red Lion MPAXI rate meter connected to a BS2 via RS-232
Currently I am sending a·looped request for the current encoder count and not accepting it until it is greater than 7000 ticks. Upon reaching the tick count I send·a request for the current rate display and resend that to StampDAQ for logging and averaging the rate for the production day. Upon completion I send a reset command to reset the internal counter back to zero and start over again.
This has been working well for a couple of days now but it still requires intervention each morning to reset the system. It would also be nice to transmit the averaged number back to a slave MPAX unit for diplay on the floor.
Here are my questions:
I see as noted above that you can send data to the stamp also.
Would it be safe to assume that I could also send cell data back to the stamp something like,
If Time = xxx Then
··············stamp.SendData J3······· 'Send data from cell J3 to stamp for retransmit to slave display.
And also would it be possible to save a days production as a worksheet and add a new worksheet at a specific time?
I will continue my MSDN search for a solution but until then, i was hoping there might be an Excel guru among us with·some insight.
······· End If
Here is my project:
If Time = xxx Then
