I just got the BS1USB.· I'm curiouse why it dose not show up on the mac with either of the FTDI drivers for the Mac.· Looking for a direction.· Anyone ...
I'm aware of this information. Thank you for your input, but the question is why when I plug my FTDI external device it is seen as Comport X: when looking at availble ports on my mac. However when I plug the bs1usb in the hardware is not recognised as Comport X. If I can not communicate with it a compiler is of no use. Is this an issue that needs to be addressed by a updated FTDI driver or is that by design?
I'm not a Mac guy so I just don't know. Have you installed the latest FTDI driver for the Mac? You'd need to get it from FTDI, we don't have it on our site.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams Applications Engineer, Parallax
I am actually in the middle of porting my BS1 Debug Viewer from VB to RB -- it's slow going though, I'm not nearly as comfortable with RB as I am with VB (that, and I have a ton of other thing happening).
I find RealBasic a bit combersome to deal with but the cross platform support is awsome. I picked it up so I could hack out serial IR programmer for LED badges. I use an IO Gear USB to RS232 cable with an older FTDI chip to connect the progrmming hardware on the Mac. So I've tested with 3 differnt drivers and where the older chip shows up the one on the BS1USB does not. Can you tell me which chip is being used on the BS1USB? I'd like to look up the datasheet. Maybe that will shed some light.
The IO Gear USB to RS232 cable uses the Prolific PL2303 chipset and they can't be used to program a Basic Stamps on a Mac running OSX according to www.muratnkonar.com/otherstuff/macbs2/faq.shtml
Update version 2.01 of the FTDI driver on the mac is now working. A reboot was in order after installing the driver. I'm starting to read debug data. I now need to parse it in RealBasic. Jon if you can give me an inside look at the info maybe I can get it compiled in OS X & windows.
You can open the VB files in a text editor and see what I'm doing.· In short:
-- when you have enough characters in the serial buffer to constitute a debug packet, grab them and append it to a working buffer
-- scan the working buffer for a sync header
-- grab and parse the values that follow the sync header
I have RB as well and have greated the UI for my project, I just haven't had time to do the serial aspect yet.· When I finish it, I'll post those files as well.· It will be intersting to see if they cross-compile without having to make any changes.
I've attached the meat of things as a text file.
Post Edited (Jon Williams (Parallax)) : 2/2/2006 8:19:16 PM GMT
Jon Williams
Brandon
Jon Williams
Following my Muse,
Brandon
Jon Williams
Brandon
http://www.parallax.com/detail.asp?product_id=604-00031
Jon Williams
Brandon
Jon Williams
