Question Re: Power Supply for Broad Current Swings
I put this topic here, and not under robotics, because it deals with general current draw issues that can brownout a Stamp:
I'm building a new robot using a Stamp II and Parallax servos. I want to run it using a single 6 volt, 1.2 amp gel cell, both for servo and processor power.
The servos are powered directly by the battery, not through a voltage regulator.
My regulator for the electronics is an LM2940 with low dropout. In order to bridge motor start pulses I've proposed the following measures:
Place a 4700uf cap to the input of the voltage regulator.
Use .200 wide traces on power supply board to ensure adequate current capability.
Add 150uf to the regulator output.
Stage the motor starts by about 20milliseconds to reduce starting pulses.
Are there any other ideas?
My earlier robots used a separate 9 volt battery to power electronics. This unit has too many ancillary controllers and digital chips to do that.
Second, what is this tremendous motor you're concerned about? The one in the servos?
Aren't you more concerned about tracking accuracy, than in reducing the startup current pulse?
I don't think you need to 'stage motor starts', but your other actions seem like good ideas.
· Use a Schottky diode (VF = 0.3V)
