Needing help with the I2C command to talk to the MAX6953 chip
I recieved some very good help form jonathan.· He sent me this information to talk to the Max chip form (i believe) a pic.
Init_Display:
i2cout dispSDA,dispSCL,dispDev,$01,[noparse][[/noparse]$FF,$FF] ' Set Intensity
i2cout dispSDA,dispSCL,dispDev,$03,[noparse][[/noparse]$01] ' Show all 4 chars
i2cout dispSDA,dispSCL,dispDev,$04,[noparse][[/noparse]%00001001]' Config Byte
i2cout dispSDA,dispSCL,dispDev,$60,[noparse][[/noparse]" "," "," "," "]' Clear display
i2cout dispSDA,dispSCL,dispDev,$60,[noparse][[/noparse]"INIT"]',fail
pause 1000
Note that line 5 is the one that displays the word "INIT" using the internal font. Lines 1 -3 init the display.
Hope this helps. If you have any other questions, mail directly to jpeakall@madlabs.info, I will respond faster that way.
So i wrote mine like this.
I cant get past the
in the debug window.· Is i because i need to do a seperate entry for each item.· ie..
Will that make it work and does it mean the same thing as the samlpe pic code sent to me?
It's Only A Stupid Question If You Have Not Googled It First!!
Init_Display:
pause 1000
Start: ' Max6953 I2C Initialization I2CStart SDA 'Set Intensity I2CSend SDA, TopSlaveID 'Addresses the top Max Chip I2CSend SDA, $01 I2CSend SDA, [noparse][[/noparse]$FF,$FF] I2CStop SDA I2CStart SDA 'Show all 4 characters I2CSend SDA, TopSlaveID I2CSend SDA, $03 I2CSend SDA, $01 I2CStop SDA I2CStart SDA 'Config Byte I2CSend SDA, TopSlaveID I2CSend SDA, $04 I2CSend SDA, %00001001 I2CStop SDA I2CStart SDA 'Clear Screen I2CSend SDA, $60 I2CSend SDA, [noparse][[/noparse]" "," "," "," "] I2CStop SDA
I cant get past the
Max6953 I2C Initialization I2CStart SDA 'Set Intensity I2CSend SDA, TopSlaveID 'Addresses the top Max Chip I2CSend SDA, $01 I2CSend SDA, $FF I2CSend SDA, $FF I2CStop SDA
Jon Williams
