use of standard servo using the PWM command?
christian_hahn13
I'm trying to use a servo i have and i was wonder if i could use the PWm command.
Note: Using BS2 and BS2e
······································ -Thanks· ·
Please forgive my mistake.
Post Edited (Kramer) : 1/30/2006 8:20:00 AM GMT
Jon Williams
Jon Williams
Jon Williams
·1+1=10
The "standard" pulse range is from 1.0 ms to 2.0 ms, with 1.5 ms being the center point.
Jon Williams
Jon Williams
csavage@parallax.com
As stated before, its unclear if you are using a C/R servo or standard servo (does it spin all the way around? If so its C/R, if not its standard). If its C/R use the advice I gave in my previous post, if its standard and you need a more precise positioning, you'll need to get a digital servo. They are more precise in positioning and thier deadband (the "slop" I was talking about) can be programmed. Digital servos are much more expensive (starting around $50), and require a programmer to program them (usually $100-$150).
·1+1=10
·· Could you please answer the questions we have for you in trying to help you with previous requests before asking new ones?· Thank you.· Is this a Standard or Contiuous Rotation Servo?
·1+1=10
·1+1=10
