Programming Help BS2 For Next IN pin...
I have a robot that has six ir pairs.· I am trying to figure out how to read pins in a loop.· pins 0,2,3,5,6 are transmitters.· Pins 1,3,5,7,9,11 are recievers.
I know this is probably obvious, but I have not been able to find an example for the last two hours.· Thanks for helping.
For x = 0 to 11 step 2 FREQOUT x,1,37500 'transmit irDetect = INX+1 '<----- WHAT SHOULD I DO HERE? All the examples use irdetect=in9 or whatever the in pin is 'do stuff Next
x=x+1
irDetect = input x
Next
Emit····· DATA··· 0, 2, 3, 5, 6, 10
Detect··· DATA·· ·1, 3, 5, 7, 9, 11
Scan:
· FOR idx = 0 TO 5
··· READ Emit + idx, emitter
··· READ Detect + idx, detector
··· FREQOUT·emitter, 1, 37500
··· irDetect(idx) = INS.LOWBIT(detector)
· NEXT
Jon Williams
but this does not seem to work...·· This returns an "Expected a constant, variable, unary operator, or "("" error.· In the help file, it looks like input is used to set a pin as input, not to read it's input.·
Make: INPUT Y
read: IN Y
Bruce Bates
Bruce,
' {$STAMP BS2} ' {$PBASIC 2.5} ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- x VAR Word 'just a temp variable y VAR Word irDetect VAR Word 'END 'save on batterys uncomment to stop stamp temporarily '-----[noparse][[/noparse]Main Program]------------------------------------------- DO GOSUB readIR LOOP FOR x = 0 TO 11 STEP 2 FREQOUT 0,x,37500 y = x+1 INPUT y [b]irDetect = IN y '<--- says IN is an undefined symbol.[/b] DEBUG HOME,"irDetect", DEC y, " = ",DEC irDetect,CR NEXT RETURNI think I am doing this as you suggested, but I am getting an error on IN y.
idx······ · VAR·· Nib
emitter··· ·VAR·· Nib
detector··· VAR·· Nib
irDectect·· VAR·· Byte
Emit····· · DATA··· 0, 2, 3, 5, 6, 10
Detect···· ·DATA·· ·1, 3, 5, 7, 9, 11
Scan:
· FOR idx = 0 TO 5
··· READ (Emit + idx), emitter
··· READ (Detect + idx), detector
··· irDetect.LOWBIT(idx) = INS.LOWBIT(detector)
· NEXT
You input pins should never be made outputs so you don't need to complicate things by using the INPUT function.· This routine gives you the most flexibility to assign your emitter/detector pin pairs (in the DATA tables)·without resorting to monkey-motion with your for next loop -- monkey-motion that, if it goes wrong, could be driving outputs into each other and creating a conflict.
Jon Williams
