Use of a poteniometer with Bs2 or bs2e
I was wondering how to use a potentiometer with my basic stamp.
Any replies are very much apprectiated.
Jon Williams
Meh. Nothing here, move along.
-Thanks
Basically, the Capacitor is charged and then the BasicStamp counts how long it takes to discharge.
The Resistor in the form of a potentiometer will change the rate at which the Capacitor discharges and this will give you a number that corresponds to the position of the potentiometer.
The BEST way for you to go, is open the help file for the stamp program editor. A.K.A the "Pbasic syntax guide", and look up
command RCTIME.
It gives you an example of using RCTIME with a potentiometer. Along with a schematic.
I don't really think you would need an extra chip just to read a potentiometer, unless you wanted EXACT results. Even then you can program a small filter program that will act like a ADC converter, in program code.
Good luck.
I think a lot of us forget that it is extremely useful and has tons of schematics with clear explanations. It happens to be the Bible that made Parallax a sucess.
Use it.
