PINK page hits
Hi all,
Has anyone determined how to count Web page hits? I have looked at all the special purpose registers could not find any clues.
Thanks Tim
Post Edited (TimC) : 1/29/2006 2:29:43 AM GMT
Thanks Tim
example(even though i dislike them): http://www.bravenet.com/
I really would like a simple solution, everything contained within the stamp or Netburner.
PINK should be able to do this. Unique users might be a problem but then again the PINK is a 32bit processor running at 95mhz.
Tim C
I've tested it on my Pink.
Best Regards from Chile
Goten
I have added the code GearHead attached. It's working!
Tim
And it counts the number of times you have the page, not the total number of times the page has been hit. Since the javascript code is execute on the client-side, in your browser. It uses cookies to store this number in your browser.
And yes, it uses an activeX component to track individual hits to a site via a cookie.
I see TimC is now using a script for Bravenet for a page counter, cool…
Page hits are a mystery when the process is hidden somewhere else.
I think avoiding cookies, activeX components and maybe javascript is best if possible.
PINK HAS a place to put a simple number. I am now grabing the number adding 1 to it but the trick is passing a value back to a PINK register without user interaction.
While my web page is active you can see this now at the TEST NB counter.
?How can I post a number back to PINK without a submit button??
Trying:
<input type="hidden" name="Nb_var01">
Is not enough.
Regards
Tim
Post Edited (TimC) : 1/30/2006 3:49:10 PM GMT
I renamed my index.htm to newhome.htm and replaced index.htm with the following file:
INDEX.HTM FILE FOLLOWS
<!DOCTYPE HTML PUBLIC "-//W3O//DTD W3 HTML 2.0//EN">
<!-- Tim's pagecounter web page for SB70 Jan 29 2006 -->
<html>
<body>
<form name="my_hidden" method="post" action="newhome.htm">
<input type="hidden" size="25" maxlength="70" name="my_url" value="">
<input type="hidden" size="10" maxlength="15" name="Nb_var01" value="">
</form>
<script>
document.my_hidden.my_url.value = document.URL;
var my_count
my_count = eval(<Nb_var01>)
my_count++
my_count = my_count.toString()
document.my_hidden.Nb_var01.value = my_count;
document.my_hidden.submit();
</script>
</body>
</html>
