Low Power, High Speed Stamp
![LoopyByteloose](https://forums.parallax.com/uploads/userpics/025/nC57NMH1BTW54.gif)
A few [noparse][[/noparse]or several] months ago, there was discussion of the possiblity of making a 3.4 volt version of the BasicStamp that would be both high speed and lower power.
Obviously, this would allow a lower voltage regulator threshold too.· Four rechargible NiMH or NiCads could be used and recharged by solar panel.
Am I just hoping, or is this being actually considered?
I do understand that there·may have to be an obvious move to 3.4volt logic or some adaption to jump over to 5.0volt logic.·
If one goes up, the other goes down?
Of course, the terms "high speed" and "low power" are relative terms.. ▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Ken
When you use more power, you get more heat.
Also, when you you more power you have more EMI problems to handle as they use more power too.
So, the answer to your question is 'no'.
On the one hand, you can have the SX-48 operate at 50mhz at 5 volts and something like 75ma
Or you can have the SX-48 operate at 50mhz at 3.4 volts and something like 40-50 ma. [noparse][[/noparse]Sorry, but I am not looking at Guenther's data].
Since Amps X Volts = Power [noparse][[/noparse]in Watts], you begin to see that the 3.4 volt solution is significantly less in Power Consumption, in Heat, and in EMI problems.
You can still clock at 50mhz [noparse][[/noparse]or faster if that is called for]. The microprocessor just runs cooler and cleaner. I suppose one might argue that 3.4 volt logic is a bit more tricky as the range between 0 and 1 is narrower, but the newer 74HCXXs seem to handle it well.
Presently, the BasicStamp is setup to automatically reset with a brown-out fuse set at about 4.5volts, so you cannot just bypass its regulator and provide 3.4volts.· Parallax has to actually program the units to have a brown-out fuse which is set at about 3.2volts and make sure the EEPROMs can accept the lower voltage too.
Having done that, it seems that switching the voltage regulator to the lower voltage would be optimal.· If you wanted a 5volt unit, you could bypass the regulator and put regulated 5volts on the direct voltage supply pin.· Of course you would be back to higher power consumption, more heat, and more EMI.
Post Edited (Kramer) : 1/28/2006 5:11:50 PM GMT
·1+1=10
csavage@parallax.com
Suppose at 5V/50MHz you are drawing 20mA.... This is effectively a 250 Ohm load.
R=V/I
R = 5V / 20mA
R = 250 Ohms
So now take your 250 Ohm load across 3.4V and you get...
I = V/R
I = 3.4V / 250 Ohms
I = 13.6mA
13.6mA vs. 20mA is a 32% reduction in current consumption
So To figure Power.... P=I*V ...
5V/50MHz = 100mW ( 5V * 20mA)
3.4V/50MHz = 46mW (3.4 * 13.6mA)
46mW vs. 100mW is a 54% reduction in power consumption.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 1/28/2006 11:30:00 PM GMT
