Fluid Control - solenoids valves & pumps - little ones?
David Halsell
Hi All,
I need to control very small quantities of water very precisely with a BS2. (for example, a single drip at specified intervals)
Does anyone know where I can get low pressure, micro solenoids valves & pumps without breaking the bank? Everything I have found is either too big or too spendy.
thanks!
David
thanks!
David
Steve
Since you say low pressure and low volume, I presume that you may be using plastic tubing that is quite flexible.
Rather than inserting a valve, you can simply 'pinch' the tubing between a backing and an eccentric cam [noparse][[/noparse]provided by the servo].
If you look at small pulleys and drive spools for rubber belted motors, you can use these to secure your tubing into a good configuration.
This has the added advantage of you already having BS2 code for the SERVO which is quite predictable in terms of both movement and speed.
Medical units use something similar to pump blood in their Heart and Dialysis Machines as it is all quite serile and avoids leakage. That is a bit more complex, but gives a good example of how to pinch your tubing.· You can also create a very good pump with a similar setup.
Post Edited (Kramer) : 1/28/2006 9:26:40 AM GMT
·1+1=10
·1+1=10
This or similar devices are used to deliver morphine to terminally ill cancer patients. While that may seem quite morbid, the point is that they are well calibrated and quite programable.
All you have to do is lay the tube through the device and you have adapted a normal IV tube from gravity drip to pump.
{I am not fixated on drug devices, m Dad was an M.D.}
The fact is this brings to mind a whole area of robotic resources that are sitting in junk piles and storage rooms of hospitals.
There is the obvious wheel chair, but also tons of carts.· An IV stand, with wheels can suspend a power cord.· Generally everything is heavy duty and often stainless steel.
The only problem is how and where to get a hold of 2nd hand stuff.· From what I understand, much of it is exported to the needy in oversea's locations as a 'non-profit' can easily sell items to the general public or 'for profit' ventures [noparse][[/noparse]it is all in the IRS tax code about non-profit organizations].
Post Edited (Kramer) : 1/29/2006 10:16:50 AM GMT
We use a soldering station that uses syringes of solder paste and flux. The syringes have various size tips for different "blob" sizes. They are not like medical syringe tips with a sharp point. I have seen syringe applicators that are driven by a stepper motor and some that are pushed with compressed air attached where the plunger would be. In the case of the flux and solder paste, the size of the droplet is determined by the syringe tip size and the duration of the air pressure applied.
Lee Harker
·1+1=10
David
You stretch rubber tubing around the rotating head. The pressure of the rollers keep fluid from escaping by gravity.
They are very accurate.
You could probably get more information by looking at pumps in some of the scientific supply houses, Sargent Welch for example,
find something that might work, then hit the manufacturers web site for photos.,,
Pharmacia makes chromatography equip, very nice, very expensive, i think they sell such a pump (They're Swedish, so their stuff is like a Volvo)
A stepper motor driving one of these heads would do the trick...
I can draw it and email it too you or post it, if you like..
Finally think about ebay, they sell alot used scientific equip..
Kangaroo pumps are really not that accurate, if they really want accuracy now we use syringe driven delivery systems...
all the patient controlled anesthesia, PCA, is syringe driven...
Might want to keep an eye out for old kitchen gear getting tossed!
Steve
http://search.ebay.co.uk/peristaltic
Steve
