BS2 Communication with Matlab
Hello. Does anyone know if i can communicate the BS/2 with matlab;; can i load files with code from matlab to BS/2. More specifically i am interested in the robotic arm toolbox of matlab. thanks.
Post Edited By Moderator (Chris Savage (Parallax)) : 1/27/2006 3:01:33 PM GMT
·1+1=10
<edit> since the stamp has an easier time dealing with numbers in thier binary format, you proably want the command structure to be a single ASCII character followed by a binary number so something like 'B'<75> where 'Letter' is ascii and <number> is binary, and 'G'<00> etc. </edit>
·1+1=10
Post Edited (Paul Baker) : 1/27/2006 2:25:00 PM GMT
So long as the number formats are consistant, and NON-decimal, the Stamp should have no problem processing them. I would run at the lowest baud rate that MatLab will support, at least at the beginning, you can always boost it up later if necessary, or desired.
Since you are defining your own "command language" here, I would also consider the rather heavy use of delimiters (commas, parenthesis, brackets, etc) which will permit you to use the (limited) string handling facilities in the SERIN formatting sub-commands. You can also use the SKIP sub-parameter to skim over the trailing delimiter if desired.
LONG before I ever put my hands to a keyboard to write the MatLab or Stamp programs, I would spend a GOOD DEAL of time with a pencil and paper developing this language, and design it as logically and in as straight forward a manner (as Paul has done in his examples). In the end you will find this is time VERY well spent, particularly since it may well be adopted for use by others wishing to do the same or similar things.
Although I know nothing about MatLab, I do have some experience in developing command languages, and to the extent that you can provide appropriate MatLab documentation, I would be happy to lend a hand. Contact me off list if you wish (see below).
Lastly, due to the availabilty of the SPSTR area (64 bytes of scratchpad RAM), I wouldn't use anything less than a BS-2SX for this project. It will also provide more "horsepower" to do the necessary string processing.
Bruce Bates
bvbates at comcast dot net
(reassemble before use)
If you want a BS2 to communicate with Matlab, you will have to program the BS2 in PBasic to communicate with Matlab, and program Matlab in the Matlab language to communicate with the BS2.
Your mission, should you choose to accept it, is to determine the best algorithm to control your robotic arm, and implement it within the capabilities of your chosen platform.
Convieniently the lower case letters d-z satisfy this criteria, so you could use x,y and z for your servos and g for your gripper. The reason delimiters are used are for frame synchronization (so you know what is the first byte in a sequence of bytes), but by using the above scheme you know on a byte by byte level if it is the first or second byte.
Also you may want to include hand-shaking in the RS232, this is because the stamp can only do one thing at a time, so the stamp may not be listening to the connection when Matlab sends a command, if the stamp starts listening and instead of receiving the first byte ('x','y','z', ot 'g'), it receives a number it knows it missed the first byte and does not acknowledge successful receipt of the command sequence, Matlab noticing an acknowledge wasn't given sends the same command again, and will continue to do so until the stamp finally acknowledges it recieved the full command sequence. This way even if the stamp misses all or part of the command sequence because it was busy doing other stuff, you can guarantee that eventually it will receive the command when it finally starts listening to the connection again.
·1+1=10
Post Edited (Paul Baker) : 1/27/2006 4:07:28 PM GMT
